imageRUNNER 7105 0212 JAM CODES
  • ziggy53
    • Jun 2025
    [Jamming] imageRUNNER 7105 0212 JAM CODES
    Have Canon iR7105 that keeps having 0212 and 0211 duplex stationary jams. Have replaced clutches, rollers, DC Controller, Fuser Assembly, deck 2 drive assembly, the whole duplex unit and still getting the jams. Am I missing something?
  • teckat
    • 16083
    Re: imageRUNNER 7105 0212 JAM CODES
    make sure that the paper guide that is attached to the Right Deck Pickup Assembly is not out of place.
    The U shaped end of the guide may be cracked and is not secure to the bushing that it snaps onto.
    also----------------------------------------------------------------------
    Clutch 21 should only be on when doing single side copies.
    Check connector 508 pin 14, it should be 24v when running duplex copies and should never go to 0 VDC.
    When running single sided it should turn on every other copy.
