Ran into this code a couple times in the last week and just updated software after verifying (on the machines that it actually works) that no drums were above 100% life. just an FYI
irc3380 e067
Tags: None
Re: irc3380 e067
What is the DC-CON version after updating the software? (Verify it on the machine)
RAchid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
"Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
Re: irc3380 e067
never go by drum % readings
look at the Test Prints /
++Check to see if the primary transfer roller spring is deformed or detached.
this model has a habit of throwing this error when ITB is old & or when u replace only one drum at a time**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: irc3380 e067
all sorts. They just point us to the drum/secondary transfer roller. If a good cleaning won't fix it I've been able to fix it with new software. It is incredibly dry up here lately thus why I've been getting the code more. Something is arcing out. It's a decent machine despite it's quirks and that drum life usually never works under display>misc
