I have a Ir 5570 leaking toner from the Cleaner unit. The toner is Hardening and breaking the Cleaner Auger/ Screw causing the toner to leak out in to the transfer area. Front fan seems to be working fine. Any Suggestions ? Replaced the Auger already once. It did it again.
Also is there any way to stop the Toner bottle from leaking? I noticed the seal looks bad, just cant seem to find a replacement.
