ir2520
  • pulkit jain
    • Dec 2012
    • 73
    ir2520
    how can i use paper A5R from drawer (I tried to use it but it show paper jam and change paper)
  • teckat
    • 16083
    Re: ir2520
    JAM CODE ???????????????????
    Paper size of the cassette can be automatically detected by adjusting the position of the
    guide plate.
    Concavo-convex area of the cassette dial is switched when the guide plate is shifted and two
    Size Switches on a printer are switched. Length and width are detected according to the ON
    / OFF combination of switches. As long as standard paper, both AB type and inch type can
    be used. However, size should be found manually on the check screen for the combination of
    A5-Rand STMT-R or the combination of B5-R and EXEC.
