E0002 - 0214 IP 7000
  • Joseph2011
    • Aug 2011
    • 88
    good morning
    I could help with this error code E0002-0214 in an imagePRESS 7000vp
    I have made ​​the change of the thermistors and thermo switch but the code continues Any advice on this problem
    thanks
  • teckat
    • 16083
    Re: E0002 - 0214 IP 7000
    Originally posted by Joseph2011
    good morning
    thanks
    turn ON the power, and then select the following to execute ERR:
    COPIER > FUNCTION > CLEAR > ERR.
    The error is cleared by turning OFF and then ON the power after ERR execution.
    E002-0214=Secondary fixing issue
    Error in temperature difference between the center and the edge of fixing roller
    0x14
    x=
    1: Primary fixing
    2: Secondary fixing
    Error: software detection of temperature difference at external heat lower roller
    When the software detects that the temperature difference between the external heat lower roller's main and the sub thermistors is 100 deg C or more for 1 sec continuously.
    1. Check that the external heat lower roller main/sub thermistors are clean and properly installed. => Clean and reinstall them if necessary.
    2. Check for any disconnection/improper connection of the following connectors.
    => Disconnect and then connect them if necessary.
    - external heat lower roller main/sub thermistor
    - between the external heat lower roller thermistor and the fixing external driver PCB
    - between the fixing external driver PCB and the fixing duplexing feed driver PCB
    3. Replace the external heat lower roller thermistor if necessary.
    External heat lower roller thermistor:
    THM303(primary fixing),
    THM308(secondary fixing)
    Fixing external driver PCB: UN304(primary fixing), UN305(secondary fixing)
    Fixing duplexing feed driver PCB: UN311
    • Joseph2011
      • Aug 2011
      • 88
      good evening:
      I've done what I recommended, but every time I turn on the printer get this error E0002-0214 only stay changing PCB
      something else that I can recommend for further review
      regards
