Canon IRC2880i Right side door part number
  • copys
    • Jan 2011
    • 7
    [Misc] Canon IRC2880i Right side door part number
    Hi all, need some help in getting a part number for the right side door on a IRC2880i.
    I have the parts catalogue and it lists the the part number for the complete door assy (FM2-5525-000) but not just the plastic door itself without all the gubbins attached.
    Item no. 115 Right Door assy.
  • teckat
    • 16083
    Re: Canon IRC2880i Right side door part number
    Nobody in there right mind attempts to strip down this door to replace it
    be smart ORDER THE Door Assembly
    • copys
      • Jan 2011
      • 7
      Thanks for the reply.
      how hard can it be to strip the door and fit to another!
      So would that mean that the door is only available as a complete assy then?
      • teckat
        • 16083
        1-be my guest if u want to strip out over 70 parts on one door
        2-yes -as far as I know
        • northernlife
          • Sep 2011
          • 847
          3) It's plastic and plastic under pressure will begin to warp slightly. 0.5mm warpage will be enough to cause you to rip out your hair. Just change the door it's only 130ish bucks.
          • copys
            • Jan 2011
            • 7
            thanks for the info guys.
            Looks like a new door then.
            • teckat
              • 16083
              Use this part # for
              RIGHT DOOR ASSEMBLY
              FM3-4151-010
              • copys
                • Jan 2011
                • 7
                Is that a modified part then?
                • teckat
                  • 16083
                  my friend gave me that # --could be ?
                  • copys
                    • Jan 2011
                    • 7
                    Thanks guys for all the info.
                    I shall order the complete door assy.
                    Out of interest, are there many problems with these doors other than the plastic door closure clips breaking off?
                    • zoraldinho
                      teacher-guide-expert-guru
                      • Mar 2008
                      • 5017
                      Depends on users.
                      • northernlife
                        • Sep 2011
                        • 847
                        None really. The pads for the delivery assembly were modded years ago so you'd get the odd 0108 in the morning or when it sat for a while. Once one of the tabs breaks though you're screwed, jam central
                        • copys
                          • Jan 2011
                          • 7
                          you would think Canon would make those tabs/clips a lot stronger!
                          But then i guess they wouldn't sell any parts.
                          • teckat
                            • 16083
                            best out there
