IR-4570 Missing Tab? :-)
  • goldencup
    • Nov 2008
    • 366
    Hi, i have Canon IR-4570 i noticed on one of my machine that on the System Settings, the Initial All Setting is missing...? Maybe a setting is to be made? Thank you very much.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: IR-4570 Missing Tab? :-)
    Initial All Settings missing??
    What are you trying to do?
    • teckat
      • 16092
      How to Change the Initial Function:
      1. Press the Additional Functions button.
      2. Hit Custom Common Settings or Common Settings.
      3. Select the Initial Function option.
      4. You will now see the options for the Initial Function. Select which button you would like as your default screen. Depending on the imageRUNNER model and the options installed, you will be able to set the default screen to Send, Mailbox, Fax, etc.
      5. Press OK, then Done 2x.
      6. You may need to reboot the machine to verify that the changes have taken effect.
      or u mean this
      'Initialize All Data/Settings' Option on the Canon Devices
      WARNING: DATA WILL BE ERASED.
      Before using the 'Initialize All Data/Settings' feature, make sure that the data you are erasing is completely unnecessary or is backed up. Canon will not be liable for any damages resulting from the loss of data.
      Note: This procedure can take some time (up to 30 minutes).
      Recommendations:
      - To prevent others user from accidentally erasing all of the data, it is recommended to register a System Manager ID and System Password so that only the System Manager can perform this procedure.
      - If you have a Fiery controller connected, enter service mode, change the IMG-CONT to 0, and reboot the device before performing this procedure.
      The 'Initialize All Data/Settings' feature will erase the following data that is stored in the machine:
      - Data stored in in-boxes
      - Address Book data
      - Scan settings registered for the Sending function
      - Mode Memory settings registered for the Copy or Mail Box function
      - MEAP applications and Licenses
      - Data saved from MEAP applications
      - The password for MEAP SMS login services reverts back to the default
      - Registered SDL (Simple Device Login) user authentication information
      - User authentication information registered in the local device authentication system of SSO (Single Sign-on)
      - Unsent documents (Reserved documents and documents set with the Delayed Send Mode)
      - Job History
      - Additional Function settings
      - Image forms registered for the Form Composition mode
      - Registered forwarding settings
      - Key pair and server Certificate settings registered in Certificate Settings in TCP/IP Settings
      It is not normally necessary to use this feature, but it is useful for erasing personal or confidential information when returning or disposing of the machine.
      To use this feature:
      1. Press Additional Functions.
      2. Choose System Settings.
      3. Scroll down and look for 'Initialize All Data/Settings'.
      4. Hit Yes.
      • KL568
        _
        • Feb 2011
        • 324
        Hi,
        Have you compare this iR4570's firmware with one of the others yet? You might need to update firmware to enabled that.
