Error 602-001 in IR2200
  • mido
    • Nov 2011
    • 177
    Hi all
    Plz I need help in IR 2200, it display an error E602-001, the customer told me someone changed the hard disk drive and worked very well, but this error occurs about three times every two to three month, and every time he replaced the hard disk to clear this error. now the customer hate this machine and hate canon because every error cost too much to replace the hard disk, so please any idea about this problem, because it not logic to solve this error, must replace the hard disk every time.
    thank you
  • northernlife
    • Sep 2011
    • 847
    Re: Error 602-001 in IR2200
    Have you tried doing a disk check? Are you uploading latest firmware when you change the disk? Are you using refurb disks from hytech? You can edit an .ini for the sst to make it happy with just about any drive there is out there.
      • 16083
      Originally posted by mido
      Hi all
      thank you
      E602-0001 =A mounting fault of the HDD is detected when the HDD is started up from
      the BOOT ROM.
      .also check the connections for the Hard Drive harness
      .HDD flat ribbon cable could be a an issue--
      Wiring
      Are the connection and the cable between connector J1025 of the main controller
      PCB and the connector J2005 of the HDD normal?
      U could have a location power issue with that many e602 errors /
      effects HDD Partitions during printing
      try performing CHK-TYPE / HD CLEAR in Service Mode.
      This May resolve the Error code. Note: CHK-TYPE and HD CLEAR can be found in Service Mode > Function > System.
      CHK-TYPE
      Use it to select a partition number for HD-CHECK.
      Using the Mode
      HD-CLEAR
      Use it to initialize the partition selected using CHK-TYPE.
      Caution Using the Mode
      1) Select the item.
      2) Press the OK key.
