i ndeed advice fo best/ high quality canon photocopier.
  • ugaa
    • Mar 2013
    • 26
    Hi, I am new to this forum nice to meet you. I want canon photo copier b/white heavy duty for business. i am expecting to print average of 15-30,000 paper in a month for long period. what is the best model to buy would some one help please. I am told canon IR5000 is the best model. is it compatible to my need?
    thanks
  • tinnyjay
    • Oct 2009
    • 663
    Re: i ndeed advice fo best/ high quality canon photocopier.
    thanks
    Buy an IR7105 and print how much as you want in a year
    "Who loves the roses,must also bear thumbs"
    • ugaa
      • Mar 2013
      • 26
      Thank you for your help i appreciate. This photocopier seems too large and expensive. I need some good photocopier more like ir5000. please give advice. by the way what about Canon iR 7095 / 7105 black and white photocopier better or worse in terms of long life? thanks
      • Hitesh_honey
        • Aug 2011
        • 19
        dear
        if ir5000 available in yr town pl go ahead it's very superior and heavy duty.
        thanks
        • mata
          • Mar 2009
          • 46
          15-30k is not heavy duty. iR 5000 is old in your market. I would say go for at least iR6570.
          Cheers
          • northernlife
            • Sep 2011
            • 847
            If you could find a local tech who knows the 5000's well they are rock stable. We have some with 4 mil + and it's still on it's original drum. Anything based on the 5000 series is generally pretty decent, 5070, 5570, 6570,etc...
            Avoid anything from Canon that starts with a 20, ir2020, ircadv c2030, etc....
            • ugaa
              • Mar 2013
              • 26
              Hi thank you guys for your help
              I have Canon iR 7095 black and white photocopier, scanners, network printers, the meter readings are from 4 million to 5 million copies 4 years old. is it too much copies a machine like this. Up to how much average copies it can reach? some one says possibly 12,000,000 and above
              please give your advice
              Thank you I love copytechnet
              • vigour
                • Aug 2010
                • 1038
                Are you trying to get rid of your 7095 and get a 5000?
                5000 is ok but not heavy duty like 7095 series.
                I service a 7105 at 22 million, they run about 350 thousand a month, and they are resisting upgrading.
                I replaced all the drive assemblies recently. I am sure it will do another 22 million.
                • ugaa
                  • Mar 2013
                  • 26
                  No I am trying to get rid of 5000. I am trying to get 7095 is that ok?. did you say 7095 can run about up to 22 milion copies and above?
                  • charm5496
                    • 2387
                    we have several 7105's with 20 million+ on them. Highly recommend this model if your volume warrants it, but if you are only running 5K a month sometimes it would be a little overkill.
                    • tinnyjay
                      • Oct 2009
                      • 663
                      If you print 300k in a month,it means you will print about 3 million copies in a year.An IR5000 will die after 3 million copies,because you will have to buy an used one,because there is no new in the market.
                      So,better for you is to spend double money for an IR7105.I have an IR7105 and before this,i had a IR105+,but nothing compare with IR7105 in its range.
                      My suggestion goes to IR7195/7105
                      Bye
                      PS.Canon IR5000 Drum Life is 2 million,Canon IR7105 Drum Life is 6 Million
