reset counter
  • mido
    • Nov 2011
    • 177
    reset counter
    Hi ,
    Plz how can I reset the counter 101???
    thnx
  • songela
    • Mar 2008
    • 216
    Re: reset counter
    Originally posted by mido
    Hi ,
    thnx
    What do you want to achieve?
    • mido
      • Nov 2011
      • 177
      Re: reset counter
      I don't want to achieve anything, just to know if we can reset or not,
      the main reason is: I bought refurbish copiers like IR 2016/18,2022,2020, IR 4570. 3570, ....
      when I checked the counter I found all the models, counters started from 4000 copies and IR 4570 was 40k copies, so I want to check if the counter changed or not.
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: reset counter
        40k is practically brand new. I would trust it more than one with 4k.
        How to reset the count? Why it's easy as copying 100 dollar bills. Very, very slim chance of pulling it off and instant fugitive status.
        • mido
          • Nov 2011
          • 177
          Re: reset counter
          but what you mean???
          can we change it or not???
          • teckat
            • 16083
            Re: reset counter
            NO
            It is illegal to tamper with this circuit in an attempt to falsify the counter readings of any Canon
            Copier
            Counter Memory, Serial Number and Main Controller PCBs work as a set and are considered the “Soft Counter Circuit”.
            The Counter Memory PCB is electronically stamped with the serial number from the Serial Number PCB. Neither the Counter Memory PCB nor the Serial Number PCB can be swapped to other equipment. The Counter Memory PCB keeps track of the total count, which cannot be erased or changed. The service counters are retained by the Main Controller. These counters can be reset manually through service mode. When the Counter Memory PCB must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the Main Controller. This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery.
            • northernlife
              • Sep 2011
              • 847
              Re: reset counter
              Well there is level 3 service mode. Can't tell ya more though. it is illegal and whoever touches it will probably lose their dealership.
              Originally posted by teckat
              NO
              Copier
              [ATTACH=CONFIG]19904[/ATTACH]
              • teckat
                • 16083
                Re: reset counter
                Any adverse affects on the machine will not be supported by Canon > or any Canon trained tech >
                if
                Level 3 service modes are adjusted.
                • northernlife
                  • Sep 2011
                  • 847
                  Re: reset counter
                  Got that right teck. You'll be in the shit with Canon real fast if they get a whiff of you doing that.
                  if
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Re: reset counter
                    The dishonesty in this world is frightening.
                    • vamoursly
                      • Sep 2011
                      • 273
                      Re: reset counter
                      Yes, dishonesty is the norm nowadays, but to be fair I reread his initial post, firstly I don't think English is his first language and secondly the way I interpreted it he is purchasing copiers he suspects that have been clocked / tampered with and was curious to know if it can be done; may be wrong but I like to give people the benefit of the doubt........
                      Vamoursly
                      • mido
                        • Nov 2011
                        • 177
                        Re: reset counter
                        Vamoursly
                        • charm5496
                          • 2387
                          Re: reset counter
                          low meter does not mean that they were tampered with. Those units could have been repossessed and just sitting in a warehouse for 5 or 6 years till you got your hands them. I see this all the time even when we have a customer who goes belly up and we have to take their machine back from them.
                          • mjarbar
                            Re: reset counter
                            It is also dependant on the enviroment they are installed in, we have iR 2022's at two customers that are 500 yards from each other, both were installed around 3 years ago. 1 has done close to 19k the other is approaching 90k.
                            As for playing with counters, it is a total no no. It drives me up the wall when I see one as I have to totally gut the machine and replace everything because you can't trust what is good and what isn't, and it isn't like the saleman saves anything because we crosscharge them for the costs and it comes out of their bottom line.
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              Re: reset counter
                              With respect to your translations, to keep asking if "we" can change it.
                              That raised as red flag, as if your company wants to change the 40k to match the other 4k.
                              But you may mean we as "us copier techs"
                              The short answer is no, you can't change it.
                              The long answer is even if you can it won't be revealed here.
