duplex in IR 2018
  • mido
    • Nov 2011
    • 177
    duplex in IR 2018
    I have a problem in IR 2018 in duplex unit. When press the switch of the duplex on the control panel ,
    it shows 1 to 2, not two sided off, and the 2 sided ( 2 to 2) not exist.
    How can I solve this problem,
    thnx
  • Cabo
    • Aug 2012
    • 41
    Re: duplex in IR 2018
    If you have installed duplex unit press again duplex button.
    • mido
      • Nov 2011
      • 177
      I pressed it again but all the options of the duplex mode not exist. only two side 2 to 1.
      all of this series are in the following procedure;
      when press duplex switch, it shows first two sided off, then change by arrow left or right to choose 2 to 1, and 2 to 2, 2 to 1, and book type,
      all of these not exist only one function exist, 2 to 1.
      is it clear or not.???
      thnx
