IR2570C Can't print
correct your post> remove the word PRINT on end of sentence
The iR 3170 and the iR 2570 copiers can be connected to a printer kit* and
the iR 3170Ci and iR 2570Ci come fully network ready with a built-in PS/PCL/UFR II printer kit and Universal Send.
*The Color Multi-PDL Printer Kit and Color Network Printer Unit cannot be installed together.
Network Scanning (optional)*
*For the iR 3170C/iR 2570C, the optional UFR II Printer Kit, Color
Multi-PDL Printer Kit, or Color Network Printer Unit must be
installed in order to use this function.
COLOUR MULTI-PDL PRINTER KIT-D1
(STANDARD FOR THE iR 3170Ci/2570Ci)
COLOUR UNIVERSAL SEND KIT-D1 (STANDARD FOR THE
iR 3170Ci/2570Ci)
Sending Function (optional)*
*For the iR 3170C/iR 2570C, the optional Color Universal Send Kit
must be activated.
Printing (optional)*
*For the iR 3170C/iR 2570C, to use the PS and PCL printer functions, it is necessary to expand the memory capacity to 1,024 MB first, and then install the Color Multi-PDL Printer Kit or Color Network Printer Unit.
on your RUI Issue/ make sure it is turned on in control panel
Be sure to enable HTTP and RUI on the copier.
Be sure to enable "Dedicated Port" on the copier.
"send anything to print nothing happens"
look under Additional Functions>System Settings>Restrict Printer Jobs
see if it is ON> if so >switch to OFF
Hi,
I have just bought my first copier, a used IR2570C. It was a small landmark for my small company, but has not worked out as I hoped.
It copies fine, but it's main purpose was to be our central printer. It is set up on the network and I can ping to it, the windows drivers find the machine and install, but when I send anything to print nothing happens. I also get error RemoteUI Contents is Not Found!! when trying to access it from a webbrowser.
We had an engineer out last week, who was unable to get it working but suggested that it might need its firmware reinstalling. He was going to charge more than the cost of a replacement machine to do this, does anyone have any suggestions of anyone in the London area who can offer this service at a reasonable price? I am quite willing to do the work myself if anyone has the software available?
He also suggested that he was not much of a fan of this model, does anyone have any opinions on whether it is worth investing much more time/money getting it working?
Thankyou for your help,
Duncan
Duncan
iR 3170Ci/2570Ci)
must be activated.
