iRC2380 LCD Panel bottom section shimmering
  • linker3000
    • Sep 2025
    Morning,
    The bottom 1/4 of the control panel on the office iRC2380 is shimmering. In all other respects the copier is working fine - it just needs the odd clean of the waste toner container sensor when it decides that the container's not there.
    Is the panel issue a common problem and likely to be solved by giving the panel connectors some attention (or even a component replacement - eg: a bad cap), or is it generally a replacement job?
    If it's a replacement, can anyone provide a p/n and source - I see a few spares on ebay and Amazon, but some are only referenced by part number.
    Also, is there an online source for a service manual (free or paid) - we're geared up to maintain it ourselves (it's not on a contract and we're an electronics engineering firm).
    Thanks in advance
  • mark260171
    Re: iRC2380 LCD Panel bottom section shimmering
    Hi
    I have had loads of these
    You need to replace the LCD screen
    FL2-1148-000 LCD CONTROL PANEL UNIT
    Cheers
    • linker3000
      Thanks for that - any suggested UK suppliers?
      I see that the part number is just for the LCD panel - is it relatively quick to fit this part into the whole panel assembly or would it be simpler to locate a whole control unit? (part no??)
      • vamoursly
        • Sep 2011
        • 273
        Yeah must have replaced about 20 of these, got bored swapping out the LCD and just sourced control panels, even a few off some 3100's (dont tell anyone)
        V
        • linker3000
          V
          Thanks everyone - I've sourced a replacement panel.
          Any good ways to get a service manual for this unit?
