Hi, can anyone please help me with instructions on how to change the autoanswer fax ring count on an irc3220?
Canon irc3220 fax ring count
Re: Canon irc3220 fax ring count
To change the incoming ring count enter fax service mode and select the following:
1.Enter service mode on the copier and enter the Fax Service Mode.
SERVICE MODE
press Additional Functions Key (once)
press #2 & 8 key at the same time (release both)
then press Additional Functions Key again (release it)
2.Select NCU.
3.Select Auto RX.
4.Highlight '007'and change the setting as desired. The default setting will be 02.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Tanksec
