iR 3045 erased data.
  • adhy
    • Feb 2011
    • 109
    Hi
    Anyone can help me, I got problem with iR3045 that written on the display " remaining data is not needed is being erased.do not turn off the main power" every time I turn on the machine.
    Any help will be apreciate.
    Thanks for advance.
  • KL568
    _
    • Feb 2011
    • 324
    Re: iR 3045 erased data.
    Originally posted by adhy
    Hi
    Thanks for advance.
    It installed with HDD Erase Kit as an added security measure.
      • 16083
      Hi
      Thanks for advance.
      Remaining Data that is Not Needed is Being Erased
      Do not turn off the power" will not clear.
      This is a normal message when powering on a machine with the optional HDD Data Erase Kit-B2.
      If the the message does not go away at all-------------------
      Replacing the Hard Disk Drive (HDD) & re flashing Firmware should resolve the problem.
      The part number for the HDD is FM3-5634-000.
      • adhy
        • Feb 2011
        • 109
        Originally posted by KL568
        Hi KL568 thanks for fast respon...can you give me an explain in details.
        best regard.
        • adhy
          • Feb 2011
          • 109
          Hi Teckat, thanks for your respon.....is it possibly if i just reinstall the firmware of the HDD without replace it?
          Thank you.
            • 16083
            Thank you.
            does the message go away when u start printing ??
            if yes > do nothing
            is the message preventing anything (copying/printing/sending/receiving)
            • adhy
              • Feb 2011
              • 109
              if yes > do nothing
              i am sorry Teckat i forgot to tell you that machine is normally(the message is go away) when we waiting for about 30 minutes after main power is turn on.
              truely this is very annoying us.
                • 16083
                if printer prints and functions ok when message is on / I would not worry
                HDD Data Erase Kit B1/ believe it can't be removed on this model / maybe transferred to a same model
                • adhy
                  • Feb 2011
                  • 109
                  hello everyone thanks for your replies...the problem has solved. the copier is run properly with no the message appears again.
                  thank you....
                  • mr.daus
                    • Apr 2011
                    • 98
                    thank you....
                    done
                    firdaus +(62)8195002007 firdaustrish@ymail.com
                      • 16083
                      thank you....
                      FINAL SOLUTION WAS ??
                      1-wait it out
                      2-disreguard
                      3-re-load firmware
                      • adhy
                        • Feb 2011
                        • 109
                        1-wait it out
                        2-disreguard
                        3-re-load firmware
                        i clear the ram on 3rd level service mode...
