ir 2318
  • pulkit jain
    • Dec 2012
    • 73
    ir 2318
    it is displaying insert drum, drum is not set
  • Rakesh
    • May 2012
    • 72
    Re: ir 2318
    first check & clean contact of the the drum charging roller & other connectors. if problem not solved then check with other working drum & HVT PCB.
    View Life As A Continuous Learning Experience...
    • teckat
      • 16083
      Re: ir 2318
      clean contact
