IR 8095- Scan Document Size
  • gcal
    Hi folks.
    We are using a Canon IR 8095 at school and one of my teachers is having a problem scanning (to pdf) large pieces of paper-- 12x18". The scanner is only scanning standard 8.5x11. Is there a way to increase the "scope" of the scanner function?
    Thanks,
    G
    • 16083
    Re: IR 8095- Scan Document Size
    Originally posted by gcal
    Hi folks.
    Thanks,
    G
    using DF or Scan off glass
    In service mode check :First Perform a SENS-INIT , and then checkto be sure the following>
    Service Mode = settings were correct
    LEVEL 1
    COPIER> OPTION> FNC-SW> MODEL-SZ>1
    COPIER> OPTION>CUSTOM>SCANTYPE>1
    LEVEL 2
    >COPIER> OPTION> FNC-SW> SENS-CNF>1
