Hi one, Hi all,
Have a small issue with a fixing roller for an IR 5055. I received a roller part no: FC7-4237 but when i tried replacing it, it didn't quite fit correctly, after placing the drive gear on to the roller you need to put on a retaining ring that holds the gear in place, this retaining ring is not round and has little notches that clip into designated slits in the roller itself. when trying to fit this retaining ring, it doesn't quite line up with the slits on the roller.
I have since double checked the parts manual to check if i may have gotten the wrong part, but the part numbers match and is correct according to canon.
Has anyone had this issue, or know what i can do to get around this issue.
thanks in advance.....
SAZ911......
SAZ911......
