ir 7105 panel dont power
  • MARDSO
    • Nov 2009
    • 31
    I have a problem in the panel of the machine! it does not connect! starts the machine starts to heat up the panel does not turn on! so get the small green light does not appear nothing more connected in the panel! please help!
  • teckat
    • 16083
    Re: ir 7105 panel dont power
    -printer powers up
    -no LCD
    -no green light
    did u check for a stuck key/button on control panel/
    all should depress and release back
    • MARDSO
      • Nov 2009
      • 31
      I changed the panel! it turns on and begins to heat but is giving an error because it does not heat up finishes! already tested boot rom and ram! this ok!
      • alexctx
        • Dec 2010
        • 158
        machine. display off
        We happened to 2 clients. is the main board.
        be careful because there are 2 version. with the letters of the serial number version known to use
        • MARDSO
          • Nov 2009
          • 31
          thanks! I will try this option!!!
          • alexctx
            • Dec 2010
            • 158
            de brasil
            • mr.daus
              • Apr 2011
              • 98
              Originally posted by alexctx
              de brasil
              be sure to install the memory is correct, or try to clean the connector first before installing memory. if the temperature is heating up, it means that there is an error in the memory.
              firdaus +(62)8195002007 firdaustrish@ymail.com
