ir 1025
  • T911
    • Jun 2007
    • 628
    ir 1025
    Noise from feed. Lubed shaft bushings transport rollers and it goes away for a while but comes back. I made4 trips out with this concern. I leave with no noise and then a couple days it bites me back. I held the Pf shaft applying a little pressure while it was feeding and it didn't make a noise. Anyone else experience a squeeking noise coming and going from the
    Feed system on this segment. Thanks much.
  • northernlife
    • Sep 2011
    • 847
    Re: ir 1025
    moaning noise as it passes registration? I'm working on the same issue atm. I'm pointing at the sep roller bouncing against the feed roller. Will let you know
