Canon NP6050 False Paper Jam
  • Thymeclock
    • Mar 2013
    • 13
    [Jamming] Canon NP6050 False Paper Jam
    When making multiple copies my Canon NP 6050 reported a paper jam at the right side center door area. I retrieved a 4" square of torn paper from that area but could not find any other jammed paper anywhere in else in the machine. I don't see how could I lose almost an entire sheet without finding it. I checked all the other trays. The machine won't operate as it is still indicating a jam. There is no paper jam anywhere and certainly not in the area being reported.
  • teckat
    • 16083
    Re: Canon NP6050 False Paper Jam
    what is the jam code ??
    • Thymeclock
      • Mar 2013
      • 13
      It's not a numerical code. The LCD display indicates that there is a jam located in the center door area on the right side of the machine. That's where I found the piece of torn paper. But now there is no other paper there at all, nor anywhere else in the machine.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5005
        Jam code is in service mode.Inspect a sensor flag around jam area.
        • teckat
          • 16083
          As many as 17 sensors are used to monitor the movement of copy paper
          PS08 /Holding tray feeding assembly 1 paper sensor =delay/stationary
          PSO9 /Holding tray feeding assembly 2 paper sensor 1=delay/stationary
          PS10 /External delivery sensor=delay/stationary
          PS12 /Internal delivery sensor (reversing assembly)=stationary jams.
          PS14 /Holding tray registration paper sensor=delay/stationary
          PS15 /Holding tray inlet paper sensor=delay/stationary
          PS17 /Holding tray pick-up sensor
          PS22 /Multi-feeder pick-up sensor
          PS23 /Registration Sensor=delay/stationary
          PS24 /Pick-up vertical path 0 paper sensor=delay/stationary
          PS27 /Pick-up vertical path 3 paper sensor=delay/stationary
          PS30 /Pick-up vertical path 4 paper sensor=delay/stationary
          PS33 /Pick-up vertical path 1 paper sensor=delay/stationary
          PS36 / Pick-up vertical path 2 paper sensor=delay/stationary
          PS47 /Fixing assembly outlet paper sensor=delay/stationary
          PS49 /Left deck pick-up sensor=delay/stationary
          PS52 /Claw jam sensor=delay/stationary
          • HP:guy
            • Feb 2013
            • 279
            Take that old horse outside and put it out of its misery.
            • Brian8506
              • 1664
              Did you remove feed assembly and make sure theres nothing in it or behind it. Large pieces of paper don't disappear easily.
              • Thymeclock
                • Mar 2013
                • 13
                I remember having to get into service mode several years ago when I had a similar problem with it. But I've forgotten how to do that, so please advise me on how it's done.
                • Brian8506
                  • 1664
                  Pin hole inside front cover. *1*
                  • teckat
                    • 16083
                    see pdf---------NP6050--Jam Indications.pdf
                    • Brian8506
                      • 1664
                      It will list the last 3 jams but just the codes. No dates etc.
                      • Thymeclock
                        • Mar 2013
                        • 13
                        see pdf---------[ATTACH]20073[/ATTACH]
                        I read the pdf, but it only says what I already know - that the indicated problem is supposedly in the right door area.
                        Did the pinhole / service mode routine. The numerals it lists in the left part of the screen are 3 & 10.
                        • Brian8506
                          • 1664
                          In service mode you have to go addl func/1/addl func/display and scroll right to b_jam page 5 of 9. And I correct myself, it gives you the 9 most recent body jam codes.
                          • teckat
                            • 16083
                            Thanks,
                            could not remember that old school stuff
                            • Thymeclock
                              • Mar 2013
                              • 13
                              Here's the display for page 5:
                              B_JAMO: 010A 010E 010E
                              B_JAM3: 010E 010E 010E
                              B_JAM6: 010E 0108 010E
                              B_ALRM: 0000
                              B_ER1: E712 0000
                              B_ER2: E713 0000
                              B_ER3: E713 0000
                              A: O
                              I don't understand how this relates to the other digits 3 & 10, but I'm sure you know more about this than I do.
