canon ir 105
  • Saji
    • May 2010
    • 97
    [Error Code] canon ir 105
    canon ir 105 showing error code 315-000d, checked all connectors, replaced reader board. still its give the code intermittently. wht could be the problem, pls help.thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Re: canon ir 105
    -Cables?
    -DIMM?
    • teckat
      • 16083
      Re: canon ir 105
      Suspected causes for E315-000D/0005 are:
      1) Defective Hard Disk.
      2) Main Controller PCB.(Damage to the compression/expansion circuit)
      3) Faulty Memory. (This error occurs on rare occasions if the recommended memory is not used).
      • Saji
        • May 2010
        • 97
        Re: canon ir 105
        Thank you..sir..
