IR 3220 fiery has colo disk full error on it
  • jake24482
    • Apr 2011
    • 116
    Hi i am working in IR 3220 has a fiery .it does not print . It shows color disk full on it .can some one tell me how to clear the disk or what can be done . please let me know.thanks in advance. i already try to clear the server but nothing happen. Its c1
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: IR 3220 fiery has colo disk full error on it
    Check this area:
    First set CHK-TYPE to 1 (COPIER>FUNCTION>SYSTEM>CHK-TYPE) and perform an HD-CLEAR (COPIER>FUNCTION>SYSTEM>HD-CLEAR) if that doesn't clear the message then perform an MMI clear (COPIER>FUNCTION>CLEAR>MMI).
    Only perform these steps if your familiar!
    • KL568
      _
      • Feb 2011
      • 324
      Also check the configuration sheet of Fiery, (if printable from your machine based on current issue). You should see HDD available size and free size. Even after CLEAR Server of Fiery, this free size does not change, it might be time to reload this Fiery HDD firmware or replace HDD.
