iR3225N Distorted image when copying
  • magc
    • 30
    Occasionally the copier makes copies distorted. Both copy the table as the ADF have the same problem. Attached to this post I send a sample of the fault. Someone could help me?
  • benerin
    • Dec 2011
    • 59
    Re: iR3225N Distorted image when copying
    Laser Unit?
    • magc
      • 30
      I do not know, because I couldn't see if it also fails as a printer or only copying.
      • northernlife
        • Sep 2011
        • 847
        Unless the fixing film is running with no film I'm pointing at laser too. If you print a report > add functions > report settings. Scan that for us so we can eliminate the scanner as a source of the problem.
        • magc
          • 30
          As I have said, I have not been able to reproduce the problem but the costumer kept these samples for me. The problem occurs occasionally. I can not send you more samples than that. When I go to my client's office copies comes out perfectly.
          • Canon.Tech
            • Mar 2009
            • 335
            That looks like a fixing film issue to me, especially if the machine has a compatible one fitted they tend to stick also check the jam history see if there are many 0107 jams
