The setting is for one side copy (two sides "off" in the menu copy selection), still duplex every copy, the scanner copy once but the paper going back to the duplex as it does on 1 to 2 sided copy, and comes out. No jams. Any idea? Thanks.
Canon MF6550 always duplex
Re: Canon MF6550 always duplex
since u don't have the following on this model (COPIER > OPTION > BODY > SCANSLCT "0"
If the setting is "1" the feeder will scan the original twice. Set to "0" for single scanning.
for iR's only
see below for your model
Enter the service mode.
Sequentially press the Additional functions key, 2 key, 8 key, and Additional
functions key on the operation panel.
Run a Scan Test in Test Mode
Scan test ((2) SCAN TEST)
Used to adjust contact sensor output and the position at which a document fed from the ADF is scanned.
Press the numeric keypad key 2 on the test mode menu to select the CCD test.
Press numeric keypad keys 1, 3 and 4 during the CCD test to carry out the individual tests described below.
Numeric keypad key 1
Corrects the LED output of the contact sensor and sets its parameters automatically. (AGC adjustment)
Numeric keypad key 3
Adjusts the document scan position (only on models with the ADF feature installed). Adjusts the position of the contact sensor for scanning documents fed from the ADF automatically.
Numeric keypad key 4
Detects trash at reader scan positions A/B/C.
Pos A: Reference read position
Pos B: About 0.5 mm inside of the roller from the reference position
Pos C: About 1.0 mm inside of the roller from the reference position
exit service mode ----and check items below/ adjust what is needed
Additional Functions> Menu
COPY SETTINGS
TWO-SIDED = Sets the type of two-sided copying.
OFF > select thisPRINTER SETTINGS
2-SIDED PRINTING
Sets whether to activate two-sided printing.FAX SETTINGS**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
did u run the Scan test ??
what size paper ? all or some or only one size ?**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
