CAnon 4570 PCL kit
  • El Che
    • Aug 2025
    CAnon 4570 PCL kit
    I have never set up u send or print kit on this models. What come in the kit? Is it just software or the boot rom has to be replaced too? Thanks for any reply
  • Tim C
    • 167
    Re: CAnon 4570 PCL kit
    In the Canon Ir4570 the Print Kit and Universal Send Kit are two different items that need separate set up procedures. When you purchase them each comes with instructions.
    • teckat
      • 16083
      Sending Function (optional)*
      *The optional Universal Send Kit must be activated by registering a license key/ when purchased the
      LMS kIT registration LAN (License Access Number) information is included , this is done online at https://c-lms.com/license/enduser/portal/LAInput.jsp(no pcb. included or needed)
      Printing (optional)*
      Multi-PDL Printer Kit E1= uses a "N" Boot Rom included in kit/ (i believe when installed to printer outside USA u need to separately purchase>install the expansion ram 256mb)
      Multi-PDL Printer Kit-E1_ install.pdf
      Network Scanning (optional)*
      *The optional Multi-PDL Printer Kit must be installed on your machine, and Network
      ScanGear software must be installed on your computer to use this function.
      • El Che
        Got it thank you for your time.
