E000001-0002 -abnormality on fixing temparature, you can reset the system thruservice
  • Mohan Singh
    • Jun 2025
    [Error Code] E000001-0002 -abnormality on fixing temparature, you can reset the system thruservice
    Hi All,
    I am new to this forum, having IR 2270 .. initially getting error E00007-0000.
    When opened the fusing assembly, reassemble .. it has started giving the above error in title.
    Queries :
    1. Fixing film has white mark it has to be on which side .. how does the sensor look like.
    2. What is the importance of grease underneath the fixing film .. is this grease is different than the other grease being used in other part of coper.
    3. Any video link on which we can see how to reassemble the the fusing assembly.
    • 16083
    Re: E000001-0002 -abnormality on fixing temparature, you can reset the system thruser
    Originally posted by Mohan Singh
    Hi All,
    Queries :
    iR4570_Fixing Unit.pdf
    • Mohan Singh
      Thanks for the PDF doc.
