Hi every body. I have seen these to machines IR C5035I or IRC5185 they both are colours. what difference do they have ???
which one is more reliable
thank your assistance
most important thingIt's up to your local supply which one is more
but for me the new model IRC 5035I is new and expensive cost but low problem on short run and more quality /more technology for connect and easy to print from handy drive
scan to handy drive maybe wifi too and new interface easier for user to use many function.
The real tank super die hard is IRC 5185 also low cost too
PS if u use paper weight more than 160 Grams too often and not require technology so much like only use for copy/print/scan/network/fax irc 5185 is anwser
Thanks bro but did not get you. what do you mean by real tank super die hard? what hapen if I use paper wheight more than 160gsm?up to how many million does it dies?
[QUOTE=nochick;351201]Sorry about that i just over emotion to mention about that model
most of meter i seen is 1.2 million on T101 and still go on
and about paper ... if u use thick paper often the ir5185 has more durable for thant kind of
Thaks appreciated
Lol, Your English is fn better than main. By the way what about ir c5185 estimate life time ( how many copies it dies) if new drum is fitted will that make deference.
thank you.
t
U replace drums instead of IRC5185 drum units.
ITB last longer 600k instead of IRC4185 300K
And the Fixing, after 400/500K u need to replace the fixing film only. For the IRC5185 u need the replace the Fixing UNIT, yes a whole unit. Every 150/200K. Also this fixing unit is very expensive an cannot be refurbished.
