IR 3570 jams in morning or very first page
  • jake24482
    • Apr 2011
    • 116
    Hi i am working on ir3570 it jams every morning and the jam code is 010d if some one can help me with this issue. what cause this to jam i replace feed and separation rollers . thanks in advance
  • kuby
    • Oct 2007
    • 1408
    Re: IR 3570 jams in morning or very first page
    Make sure the pads that the Flapper (FC5-1354-000 - FLAPPER, FIXING DELIVERY REV.) rests on are not worn or sticky. If there are you need to put a piece of tape on them or I use baby power to get rid of the sticky feeling. If the flapper sticks it will jam right at the fuse. Just something to look at.
    • jake24482
      • Apr 2011
      • 116
      I think i got it . I think it has a bad one way gear in duplex unit
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Kuby got a point.
        • Brian8506
          • 1664
          If the jam code is 0108, these guys are right especially if its worse in the morning.
          Originally posted by zoraldinho
          Kuby got a point.
          [ATTACH=CONFIG]20168[/ATTACH]
          • mido
            • Nov 2011
            • 177
            you can remove the pads and will never jammed any more in this unit.
            • danko72
              • Jan 2012
              • 13
              Thanks Kuby that was the solution.
