CANON IR 2318 ERROR E261 !!!! Don't found it in the manual !
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] CANON IR 2318 ERROR E261 !!!! Don't found it in the manual !
    Hi to all
    i have canon ir2318 desplaying E261 Err , but i did not found it in her Manual can anyone help me!
    Thank you in advance..
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    Re: CANON IR 2318 ERROR E261 !!!! Don't found it in the manual !
    try this idea : The intervals of zero-cross signals deviate from the tolerance range while the fixing heater is supplied with power......
    BEST TECHNICIAN . NICE PEOPLE .
    • teckat
      • 16083
      Originally posted by sweet.persona
      Hi to all
      E261 can be caused by no /or poor voltage from the wall outlet or if the circuit breaker is tripped.
      Power supply PCB-High-voltage power
      supply PCB
      CPU on the DC controller monitors the voltage of the M_TH/S_TH signal to control the fixing heater 1 drive signal (H1DRV) and fixing heater 2 drive signal (H2DRV). These two voltages are generated based on the zero crossing detection signal which is output from the heater control circuit. The CPU controls these two signals to adjust the fixing heater temperature to the prescribed value.
