Password recovery or reset to factory default on IR 1730i
  • faraflunz
    Hi folk,
    we have a Canon ImageRunner 1730i printer.
    For some reason, I can't login using default Manager credentials (7654321 - 7654321).
    How can I reset the printer settings or jus the Manager ID/Password?
    Thanks.
  • teckat
    • 16083
    Re: Password recovery or reset to factory default on IR 1730i
    Originally posted by faraflunz
    Hi folk,
    Thanks.
    in service mode
    Start [Service Mode].
    1) Press [Additional Functions (User Mode)] button on the control panel.
    2) Press #[2] button on the control panel.
    3) Press #[8] button on the control panel.
    4) Press [Additional Functions (User Mode)] button on the control panel.
    #CLEAR
    Use it to reset various data to initial settings.
    #CLEAR
    PWD= Clears the system administrator's password.
    • faraflunz
      It worked.
      Thanks a lot.
      I pressed sequentially
      additional function
      2
      8
      additional function
      then clear -> pwd
      Then I switched off the printer.
      Thank you very much.
      • teckat
        • 16083
        It worked.
        Thanks a lot.
        additional function
        2
        8
        additional function
        then clear -> pwd
