Canon 2550 Error code E020-0013 black Drum
  • sagar4
    • Dec 2012
    • 127
    [Error Code] Canon 2550 Error code E020-0013 black Drum
    Black drum has scratches on it causing lines on copies. Went to replace black drum now getting error code E020-0013. Put back old drum test good. Any ideas thanks. Already checked the sensors and cleaned. But remember put old drum back in copier works fine put new drum and copier gives error code. Thanks
    "Broken again"
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: Canon 2550 Error code E020-0013 black Drum
    The ? I have is??
    You said you replaced the black drum.. Was this drum, a brand new one?
    When you replace any drum unit the fuse on the drum unit blows.
    What does the life for the black drum look like under service mode now?
    What is the value?
    What's the count on this machine?
    • sagar4
      • Dec 2012
      • 127
      Originally posted by SCREWTAPE
      The ? I have is??
      What is the value?
      Brand new drum from canon. Count on machine 226,000 pages. I would have to go back and look at drum count but drum is brand new.
      "Broken again"
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Check.
        Next ?
        Has that ITB unit ever been replaced?
        • sagar4
          • Dec 2012
          • 127
          Check.Next ?Has that ITB unit ever been replaced?
          yes itb replaced today still problem exsists
          "Broken again"
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Bad DC controller.
            You change that too!
            • sagar4
              • Dec 2012
              • 127
              Bad DC controller.
              No did not change the dc controller. But again if I put back the old drum copier works just fine. But put in new drum copier cycles and then error code pops up. Weird.
              "Broken again"
              • SCREWTAPE
                East Coast Imaging
                • 3396
                NOT WERID AT ALL.. It happens!
                You can try cleaning the laser slit glass on the black laser as well.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Other things to check:
                  1. Check to see if the ATR shutter comes off; if so, re-fit it.
                  2. Wipe the ATR sensor window with a damp cotton cloth.
                  3. If the symptom still occurs, replace the ATR sensor with a new one.
                  FK2-0494-000 - Reflector Type Photo-sensor
                  • sagar4
                    • Dec 2012
                    • 127
                    I will give it a shot. Thanks for all the support much appreciated.
                    "Broken again"
                    • yop190
                      • Feb 2021
                      • 2
                      Hi,
                      I have the same problem, I have just replace the black drum and now I have the same error code.
                      So, Where is the the laser slit glass ?
                      How to clean it ?
                      Cheers,
                      • yop190
                        • Feb 2021
                        • 2
                        Originally posted by yop190
                        Hi,
                        How to clean it ?
                        Cheers,
                        In fact my problem was just : I have not shake enough the drum
