Canon IRC2380i photocopier always jamming
  • martinn12003
    I'm new to this forum. I found it whilst trying to find a solution for the problem with my photocopier. Hopefully you can help me.
    Regardless of where the paper is being fed from, whether it's the feeder, stack bypass tray or the bottom feeder, the copier is always jamming and giving me the following error message:-
    Press [shutdown] key. After the machine has been shutdown, turn the main power switch (on the right side of the main unit) off and on again. If the machine still does not operate normally, contact your service representative with the error code below.
    E000747-0c19
    I've checked the paper quality and all the usual stuff but nothing seems to work. Does anyone know what is wrong with it or what the error code means?
    Regards
    • 16083
    Re: Canon IRC2380i photocopier always jamming
    Remove > clean ends & re-seating all boards on the main controller can resolve E747 codes
    see pdf--------
    Board Cleaning_Board Position-TP07 094.pdf
    this applies to all models with these pcb's even if your model is not listed /works 95% of the time
    • martinn12003
      Thanks for that. I will try that out.
      I have also just started receiving this error message : E000732-0001. Will the pdf you attached also help this error too? If not, what is causing this?
      Thanks again
        • 16083
        Originally posted by martinn12003
        Thanks again
        I believe so
        • vamoursly
          • Sep 2011
          • 273
          +1 to above, just be sure to vacuum out the dust, use a non abrasive cleaner on the PCB's, dont damage any contacts;
          I have seen this error almost as many times as I have seen faulty screens on the IRC2380 -3580i series
          V
          • martinn12003
            Thanks everyone.
            It worked like a charm!!! Happy printing
            • vamoursly
              • Sep 2011
              • 273
                • 16083
                Thanks everyone.
                • Nussi34
                  Great thank you! Worked also for me!
