Help Needed
  • mukhtar
    • Jun 2025
    Help Needed
    Hi All
    I need help with My canon IR 3100C, There is no power at all, The Machine was working fine before, Came one morning and I switched it on and no power came on, I changed the power lead and used different socket but still no power.
    Any advice are welcome.
    Thank you
  • mr.daus
    • Apr 2011
    • 98
    Re: Help Needed
    Originally posted by mukhtar
    Hi All
    Thank you
    apakah setelah di nyalakan, indikator lampu kekuatan yang berwarna hijau menyala?
    jika tidak coba anda periksa kabel utama listriknya, periksa juga saklar listrik utama pada mesin
    firdaus +(62)8195002007 firdaustrish@ymail.com
    • mukhtar
      Re: Help Needed
      Hi Firdaus
      Thank you for your message but I cannot understand Indonesian language, Can you write in English ?
      Thank you
      • teckat
        • 16083
        Re: Help Needed
        Hi All
        Thank you
        No power, blank display and the green Power >indicator is off.
        is all this true ??
        Check for AC voltage into the Printer Power Supply, & DC voltage out of the Printer Power Supply.
        look on Main Controller >see if LED 2 and LED 5 are both off.
        If there is no outputs from any of the DC Power Supplies.
        May be necessary to replaced the following PCB's as a set: the Main Controller Power Supply and the Printer Power Supply . Note: The Printer Power Supply is also called the Main Power Supply in the part catalog.
        • KL568
          _
          • Feb 2011
          • 324
          Re: Help Needed
          Hi,
          Any Electrical surge recently? Look for circuit breaker behind the machine rear cove, it might have been trigger to OFF.
          • teckat
            • 16083
            Re: Help Needed
            Originally posted by KL568
            Hi,
            • mukhtar
              Re: Help Needed
              is all this true ??
              Hi
              I try to look for the above but I was not able to see anything, I think this is going to be too technical for me and I will probably need to call a Printer service engineer.
              • mukhtar
                Re: Help Needed
                [ATTACH=CONFIG]20250[/ATTACH]
                Hi thanks for the Photo I will check out this tomorrow.
                • mukhtar
                  Re: Help Needed
                  Hi I just remember before the printer went off, I moved it by pushing hard from behind,
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Re: Help Needed
                    Possibly flipped the breaker lever?
                    • mukhtar
                      Re: Help Needed
                      The Breaker leaver was off, I tuned it on and the machine started working.
                      Thank you very much,
                      • teckat
                        • 16083
                        Re: Help Needed
                        • vamoursly
                          • Sep 2011
                          • 273
                          Re: Help Needed
                          No paypal this time?
                          V
