I have a canon Ir2520 It had a error of E00002 when i try to reset that its not booting properly and restart often and we cant enter into service mode also, i think it is the problem with the firmware can now when i turn on the last switch in the controller PCB it shows ''Network download available" and giving one IP address. now how to get a firmware and software to install the firmware, is there any other way? please let me Know
Not Booting
Daniel_navarajTags: None
Re: Not Booting
'Network Download Available, =remove & re-seat the Memory Dimm
How to clear
Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions. #SSSW will be displayed. Use the right arrow and scroll to #CLEAR then press OK. Use the right arrow and scroll to ENGINE then press OK. ERRCLR will be displayed then press OK. Then power cycle the machine.
E002- check your fuser or wall voltage
If the E002 Error will not clear, check to make sure the voltage at the wall outlet is within spec for the imageRUNNER. The voltage across the Hot and Neutral of the wall outlet should be 120 Volts AC +/- 10%. If the voltage is not within that range, then the wall voltage is out of spec for the imageRUNNER.
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: Not Booting
How to clear
Re: Not Booting
INDIA is = 220 V 50 Hz
Residential power supplied in India is two wire 220 volts, permitted variation 6%, and maximum load 40 amperes. Frequency 50 Hz. Many power outlets are universal and accept many plugs without adapter. A combination receptacle for types C, D and M is usually present.
Electrical sockets (outlets) in the Republic of India (Bhārat Gaṇarājya) usually supply electricity at between 220 and 240 volts AC
PAKISTAN is = 230 V 50 Hzany way OUTLET must be checked for correct supply
240v-220v
You should see 220V between both hots, 110V between either hot and neutral, 110V between either hot and ground, and 0V between neutral and ground.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Daniel_navaraj
Re: Not Booting
the problem is when i try to reset the err in *28 ie service mode it happened like that then after that i cant get the service mode ant the machine is not booting fully the display struck when its loading inbetweenComment
Re: Not Booting
pull out the memory> clean ends> re-seat>power up**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: Not Booting
Did you try to do the corrective measures as suggested by teckat?....removing and re-seating the DIMM? Follow that advice, step by step and post to us the result; this will lead us to the next possible solution to the problem.Comment
