IRADV4035 with repeat image.
  • THUK
    • Jul 2008
    • 195
    Hi i have a 3 day old IRADV4035 which is giving me repeat image i have changed the Dev,Drum,Fuser and the whole of the right hand door assy, i have also adj fuser temp to max and min and none of this has made a difference.
    has anyone seen this problem.
  • qbert69
    • Mar 2013
    • 1152
    Re: IRADV4035 with repeat image.
    ....is it happening when you copy?....when you print?.....or both?
    If it only does it when you print, it may be that the print driver paper type/thickness settings are overriding the paper type/thickness settings on the printer itself and you're getting a fuser offset image. Make sure the paper thickness settings are correct if it is doing it only when you print!
    CHEERS!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5000
      Drum Ghost? Post a sample please.
      • THUK
        • Jul 2008
        • 195
        hi its not the Drum,Dev,Fuser or right hand door assy.
        • THUK
          • Jul 2008
          • 195
          It does it with copy and print.
          • zoraldinho
            • Mar 2008
            • 5000
            Post a pic.Use test print.
            Capture.JPG click for better view
            • THUK
              • Jul 2008
              • 195
              [ATTACH=CONFIG]20314[/ATTACH] click for better view
              hi i got Canon to come out and look at the mc and the fault has disappeared i could not believe it so god knows what it was thanks for your reply.
