hello, i got a canon iR C3380 i wasnt sure what was wrong it powers up no error messages but when i try to connect to PC via USB i get the following errors, if i use the set up it says" CANNOT RECOGNIZE USB CONNECTION" tried new usb cable and PC port no luck and when i use windows xp install a new printer wizard it gives the following error"CANNOT PRINT BECAUSE THE VERSION OF THE DEVICE DEVICE CONTROLLER IS OLD. Any help to solve this is welcome, thanks.
Canon iR C3380 USB install WINXP
Re: Canon iR C3380 USB install WINXP
imageRUNNER 2016 / 2020 / 2230 / 2830 / 3530 / 2270 / 2870 / 3570 / 4570 / 5070 / 5570 / 6570 / 85+ / 8070 / 9070 / 105+ / 7105 / 7095 / 7086 / 3025 / 3030 / 3035 / 3045 / 5055 / 5065 / 5070 / 5075, imageRUNNER C3170 / C5870 / C6870 / C4080 / C4580 / C5180 / C2880 / C3380 / C4080i / C4580i / C5180i / C2880i / C3380i, All imagePRESS Series
Printing from a PC via a USB cable can only be used when the Canon Multi-PDL Printer Kit is installed.
Using a USB Device
1) Press [Additional Functions]
2) Press [System Settings]
3) Press the up and down arrow key until [Use USB Device] appears and select it.
4) Select [ON] or [OFF].
ON - The machine accepts job through the USB Interface.
OFF - The machine does not accept jobs through the USB Interface
5) Press [Done] repeatedly until the Basic Feature screen appears.
Using a USB Host
Set Use USB Host to 'On' to connect a host device with the machine via the USB port.
1 Press (Additional Functions)-[System Settings] - [USB Settings] -[Use USB Host].
2 Select [On] or [Off] - press [OK].
The imageRUNNER-iR Series models support USB 2.0 High Speed printing via one USB 2.0 port located on the machine's main controller board. This USB port will look like this:
This is the only USB port on the machine that will support USB Printing.
Do not attempt to print using a USB Port on the machine that looks like this below:
In order to print via the USB port, the following items are required:
1. The appropriate Canon Printer Kit must be installed in the imageRUNNER.
2. The imageRUNNER-iR Series models do not ship with a USB cable. A USB 2.0 High Speed cable must be obtained on your own.
3. Make sure the 'Use USB Device' setting on the iR is turned 'On'.
Enabling the 'Use USB Device' setting on the machine:
I. For most imageRUNNERs follow these instructions:
1. On the iR, press Additional Functions.
2. Press System Settings.
3. Press Network Settings.
4. Scroll down to 'USB Settings'. Press USB Settings.
5. Select the 'Use USB Device' option.
6. Set it to 'On'. Hit OK.
7. Reboot the imageRUNNER for the changes to take effect.
II. To Enable the 'USB Device' setting on the imageRUNNER 2020/2016 Series:
1. On the Control Panel, press Additional Functions.
2. Scroll to and select 'System Settings'. Press OK.
3. Scroll to and select 'Use Device USB'. Set to 'On'.
4. Reboot the imageRUNNER for the changes to take effect.
NOTE: This 'USB Device' setting is only for printing via the USB port on the main controller board. This USB port does not support External USB Devices (mouse, keyboard, etc), the Remote User Interface (RUI), Network ScanGear, or Universal Send functions.
Other USB Ports:
Some imageRUNNER-iR Series models have optional expansion boards available that provide additional USB ports. These USB ports look like this:
In order to connect an External USB Device (mouse, keyboard, etc) to these USB ports, make sure to enable the 'Use USB Host' setting on the machine. When this is set to 'Off', the connection is disabled preventing the use of an External USB Device. See your specific imageRUNNER model's documentation for specifications on what External USB Devices are supported.
These USB ports CANNOT be used for printing. Use the USB port on the main controller board for USB printing (as described above).
Last edited by teckat; 04-10-2013, 10:05 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
The Fiery is a "box" that mounts on the back of the machine, and is your print controller.
It will have 2 network ports on it (one to the wall, and one to the copier), as well as a SCSI type cable connector to the copier.
Assuming you have no Fiery, what version of USB is your PC? If it is 1.0, I don't think the copier will see it correctly.
Most PCs are version 1.1 or 2.0, and the newest ones are 3.0.
I do know that 1.1 and 2.0 work; I'm not yet been blessed with a 3.0 yet to know if it will. I would think 3.0 is backward compatible down to 2.0 and 1.1 speeds.
Confused yet??“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
for the imageRUNNER C3380 / C2880 / C3380i / C2880i SERIES
These are the available print options/ only an "i" series has PCL Printer Kit -Q1 (as standard)
PCL Printer Kit-Q1=LMS License kit must be purchased then activated for use
or
PS Printer Kit-Q1=LMS License kit must be purchased then activated for use--
PS Printer Kit-Q1 requires that PCL Printer Kit-Q1 and iR 512MB Expansion RAM-C1 be previously installed.
or Fiery imagePASS J1( u don't have this)
You can check for the LMS-based Printer Kit on the Canon device the same way as you would check for any other installed LMS-based option or kit.
Perform the following steps:
1. Press the [Counter Check] button on the copier control panel.
2. Hit the [Device Configuration] button on the LCD screen.
3. Scroll down through all of the available pages on this Device Configuration screen. Look for either PS, PCL or UFRII. The methods listed here (ex. PS, PCL, or UFRII) are installed and are available for printing.
For example, if you find UFRII and PCL, but do not find PS on this screen on an iR C5180, it means that the UFRII/PCL Printer Kit is installed, but the PS Printer Kit is not installed. The exact Canon Printer Kits available vary by device model. See your specific device's documentation for more information.
* Note - You will need to install the appropriate printer drivers on the workstation in order to print.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
hi, i got a little busy...but i followed your advice and installed it on the network and it worked didnt take long, should have tried this from the beginning!! so i have another question i have the fax board its not installed how hard is it to install do i need to do some kind of configuration to set it up?Comment
