canon ir 2318
  • pulkit jain
    • Dec 2012
    • 73
    canon ir 2318
    ir 2318 is displaying error code E000805-0000 what does it mean!!!!!!!!!!
  • teckat
    • 16083
    Re: canon ir 2318
    E805 0000= Fan failure
    (Main body fan error)
    - Check the fan connector.
    - Replace the fan.
    - Replace the DC controller PCB.
    fan to cool the fixing unit.
    Switching between full-speed rotation and half-speed rotation is controlled as described below.
    1) Full-speed control
    When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn the heat exhaust fan at the full speed.
    2) Half-speed control
    When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to turn the heat exhaust fan at the half speed.
    • cashzola
      Firmware for canon ir 2318
      I am new to copytechnet,...can anybody out there help me with my canon ir 2315 please....?i already have the sst and need some one to help me get the firmware please.....hope to hear from you soon.
