canon language problem
  • NINI3909
    • Jul 2025
    i have an Canon ir2800 Printer with schwedish Language and need to turn it to a french or at least a english version.
    Can anybody send me the corresponding Firmware version with the needed SST and a brief description?
    Thank you all very much in advance
  • teckat
    • 16083
    Re: canon language problem
    Press: * Additional Function key
    Press: Common Settings
    Press: The up/down arrows until (Language Switch) appears.
    Press: Language Switch
    Press: On
    Press: Arrow keys up/down to display desired Language
    Press: Done
    Note: If the improper Language still comes up turn the machine off and back on.
    or u may need to use SST with 2800 firmware loaded to change Language FILES
    • NINI3909
      Hi bro
      i realy need sst 3,21 and ir2800 french or english language files.
      e-mail: nini.tchagn@gmail.com
      • JustManuals
        • Jan 2006
        • 9838
        Everybody is 'your bro' when you need something. Don't hold your breath. I'm sure some 'hero' will come along if you wait long enough.
        • spectraindo
          • May 2008
          • 313
          You asked for help, and somebody helps you.
          But you even did not say thank you but asked more.
          Search yourself in the Service / User Manuals.
          • DANIELCANON
            • Jun 2011
            • 187
            quizas te ayude, te envio un archivo.
            • DAG COPIERS & COMPUTERS
              • Oct 2010
              • 860
              Hi bro
              Be systematic in your 'fault diagnosis'. You have asked for help on how to switch the language from Swedish to English, and teckat has replied well guiding you on how this can be done. Why don't you first try the teckat method, see if it works and post back the result of your finding on the forum? then further help will follow; or are you merely interested in having the sst/firmware. First thing first...
              • NINI3909
                • teckat
                  • 16083
                  mismo firmware
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Everything is available for a price, how much are you prepared to pay?
                    Paul@justmanuals.com
                    • Canuck
                      Tech Specialist
                      • 1713
                      Service mode...Copier-Option-Body-Config....pick the correct country,language,destination(market) and paper config(Inch or Metric). Reboot
                      • NINI3909
                        hello everybody,
                        I really have trouble loading the French or English language in my copier. Can somebody guide me in describing the procedure to follow.I use SSTv173
                        Thank you davance.
                        • NINI3909
                          HI EVERYBODY
                          • teckat
                            • 16083
                            HI EVERYBODY
                            SERVICE MODE------------------>(*)key then(2,8)keys then(*)key
                            locate below in order------
                            COPIER>OPTION>BODY>CONFIG
                            Use it to select any of the multiple pieces of firmware stored on the hard disk to suit the selected destination and paper size:
                            Settings: XXYYZZAA
                            examples below------------
                            XX: country (JP), YY: language (ja), ZZ (00): destination, AA (00): paper configuration
                            The method of indication COPIER>DISPLAY>USER>LANGUAGE
                            The selections in parentheses are (example default selections); for the country and the
                            languages, names are given.
                            Using the Mode
                            1) Select <CONFIG>.
                            2) Select the item to change (to highlight), and press the +/- key.
                            3) Each press on the +/- key move the selection to the next item.
                            4) When the desired item is indicated, press the OK key.
                            5) Turn off and then on the main power switch.
                            SERVICE MODE
                            Indicates the language/paper size configuration used.
                            Indication < LANGUAGE xxyy.zz.aa>
                            Where,
                            xx (higher 2 characters): country code (See JIS.)
                            yy (lower 2 chargers): language code (See ISO639.)
                            zz: destination code (00: Canon, 01: OEM,02: common (all))
                            aa: paper size configuration code (00: AB, 01:Inch, 02: A, 03: all sizes)
                            • NINI3909
                              Thank you brother,I will try it .
