inner finisher B1
  • montana
    • Aug 2008
    • 393
    inner finisher B1
    hi everybody....i am facing aproblem with installing the inner finisher B1 ....after i inatalled the finisher and turn on the machine the machine starts ok but the finisher does not start....and no response at all..it does not move..i mean totally dead...i replaced the finisher power supply but it is still the same
    no error messages or error code the machine copying and the copy jammed in the finisher area...is there any ideas like setting or programming
    thanks
    • 2621
    Re: inner finisher B1
    The machine has got a two way unit B1 fitted?
    Depending on whether the machine has a two way unit as standard there are sometimes three wires from the machine that plug into the power supply, not two as indicated in the instructions. Remove the power supply and have a close look for another power type wire.
    • montana
      • Aug 2008
      • 393
      thanks for reply mr skynet.....i will check it out
        • 16083
        thanks
        on what model Printer ?
        • montana
          • Aug 2008
          • 393
          hi....on canon imagerunner 2520....thanks
          • montana
            • Aug 2008
            • 393
            hello...i checked the power supply but i wonder how could i know the missed wire connection could you specify it mr skynet?
            thanks............i apreciate your help
              • 16083
              did u check the harness connections ????
              also check the connections on Finisher Controller PCB
              did u check for 24VS between internal Power Supply Unit-U1 and Finisher ????---------CLICK ON PIC>BETTER VIEW
              • Jamesu
                • Mar 2012
                • 101
                Sorry to hi-jack a thread but i'm also having a problem with finisher B1
                Works fine and staples, but when double sided is asked of it it will jam in the 2 way unit B1. (Reversal pass option)
                Thanks.
                Have you tried turning it off and on? No...Oh, it works now!
                  • 16083
                  Thanks.
                  JAM CODES ??
                  • montana
                    • Aug 2008
                    • 393
                    [ATTACH=CONFIG]20414[/ATTACH]
                    [ATTACH=CONFIG]20415[/ATTACH]
                    hi..thank you mr tekcat for the pics that you sent...but there is a missed part on the second pic...could you please send it full....thanks again
                      • 16083
                      CLICK ON PICS> better view
                      • cyberhiway
                        • May 2011
                        • 1
                        Hi all friends , anybody have inner finisher B1 service manual and catalog ?
                        • Canuck
                          Tech Specialist
                          • 1713
                          Go into service mode....is machine seeing finisher? Is there a SORTER tab on initial service mode screen?
