Please someone help, how to set the A3 paper size at drawer 3 on my IR 5075. The default size was set at 11" x 17 ".
Thanks.
---------------------------------------------- Markings on the Width Guide Rail>>> SET TO Mmarking
The width guide rail mounted inside the cassette is provided with paper size detecting holes identified by means
of markings from A through M.
If the user reports skew movement, for instance, ask him/her to communicate the marking so that you will know
if the paper width is correctly set.
(The purpose of these markings is not disclosed to the user.)
The machine uses the paper size sensor mounted to the rear of the cassette holder to identify the size of paper
inside the cassette.When the cassette is slid into the cassette holder, the paper size sensor is pushed by the boss on the cassette,permitting the machine to detect the width and the length of paper. The DC controller PCB identifies the size of
the paper with reference to the combination of its width and length, and communicates the result of identification
to the controller unit and the reader unit. The boss pushing the paper size sensor works in conjunction with the guide plate inside the cassette, and its
location is determined when the guide plate is set to suit a specific paper size.
Cassette Settings 1) Hold down the cassette release button to slide
cassette to the front.
2) Set the side guide of the cassette onto the hole
of the mark M (A4/A3). remove the inch-series block from inside the cassette/ reserve to change back to inch size paper block.JPG
then >>>>>>>>>>
in service mode=(*key) (#2,8 keys) (*key) Cassette 3
COPIER > FUNCTION > CST > C3-STMTR/A4R
Use it to register the paper width basic value of the
cassette 3.
1) Put STMTR/A4R paper in the cassette3, and
adjust the slide guide plate to the width.
2) Select C3-STMTR/A4R to highlight, and press
the OK key so that the machine executes auto
adjustment and register the value.
