I have a problem with the scanner in a C3220 that does not return fast/far enough when using the DADF-K1. (letter size copies)
If copying single pages, no problem. Even two pages usually are OK.
But typically on the third page the scanner does not return to the start position before lighting up and scanning what ends up being part of the third and part of the second page.
By the fourth page, the scanner ends up hitting the right stop and humming. Oddly, there are no error codes thrown (wouldn't the home position sensor need to be reached between pages?).
So, here it is with --- for scanned locations and ___ for scan bed.
1: |--------__________|
2: |--------__________|
3: |_____--------_____|
4: |___________-------|
5: |_______________---|
Essentially, after the first copy, the scanner only "returns" a few inches, and starts again from there.
Any ideas as to the problem and how to fix it?
I do have a donor machine available, but what component is at fault here?
Thanks!
Thanks!
