Any time i add paper to the manuel feed and select the paper type it will responds ok, but immediately i press the start key it will ask mw to load paper to the bypass again please help
Ir33200 black and white copier
Re: Ir33200 black and white copier
u mean a iR3300 ?
u add paper then select a TYPE ? what TYPE ? u mean paper size ?
Multi-feeder
The width of paper is detected by a variable resistor operating in conjunction with the movement of the slide guide. The slide guide is set when the user adjusts the multi-feeder tray to suit the paper placed on it.
COPIER>ADJUST>CST-ADJ>MF-A4R
Use it to adjust the paper width basic value of A4R paper for the manual feed tray.
COPIER>ADJUST>CSRT-ADJ>MF-A6R
Use it to adjust the paper width basic value of A6R for the manual feed tray.
Use it to adjust the paper width basic value of A4 paper for the manual feed tray.
also
COPIER>FUNCTION>CST
Use it to execute size automatic adjustment for the multi-feeder.
Use it to adjust the paper width basic value for the multifeeder.
A4R: width: 210 mm, A6R width: 105 mm, A4 width: 297 mm
Caution To make fine-adjustments after entering the basic value, use ADJUST>CSTADJ>MF-A4R, MF-A6R, MF-A4.
(see above)
Using the Mode**Knowledge is time consuming, exhausting and costly for a trained Tech.**
