Hi,
One of my machine, canon IR3530 shows the error code of E100 0001.
Actually at first it shows the error code of 110 0001 and i checked the laser unit. I found that the laser motor was stucked. i rotated the motor manually some times and it started to run smoothly. and i mounted the laser unit. After that it shows the error code of E100 0001. I checked the BD pcb connector, right side door and is laser shutter operating normally. I did,t found nothing abnormal. pls help me.
Warm Regards
Binesh
Warm Regards
Binesh
