IR-3200 shrinking image in paper feed direction
  • copyhere
    • May 2009
    • 112
    Hi, I have a 3200 that is shrinking the image only in the paper feed direction by about 1/4 inch on letter paper and 1/2 inch in 11X17 paper. It is only shrunk in that direction in the front rear direction it is perfect. I have tried adjusting pve offset and mag h-k and it does not do anything.
    does anyone have any sugestions that would cause this?
  • vigour
    • Aug 2010
    • 1038
    Re: IR-3200 shrinking image in paper feed direction
    is it on the glass or from the DF
    • teckat
      • 16083
      Shrinking ??
      u mean the lead edge registration is off
      if this is on glass & prints could be a Drum Drive Assembly issue/ had those before
      Post a PG10 test page
      • copyhere
        • May 2009
        • 112
        No it's not the lead edge registration being off. When you print from the computer or make a copy off of the glass it reduces the image in the paper feed direction only not in the front-rear direction. On a letter copy it shrinks the image along the 8 1/2 direction but not the 11. On LTR-R it shrinks the image in the 11" direction not the 8".
        I will post test print later when I go back.
        thanks
        • teckat
          • 16083
          thanks
          imageRUNNER C3200/3220/2620
          Shrinking image
          When printing, copying or making test prints the image is reduced in the paper feed direction only.
          Solution :
          Replace secondary transfer roller
          One Note: may or may not help
          COPIER>ADJUST<FEED-ADJ>REGIST
          Used to adjust the registration roller clutch ON timing.
          Increasing the value by 1 moves the image by 0.1 mm in the direction of the leading edge of the paper.(effects>all printing, copying )
          • If you have cleared the DC controller PCB’s RAM or replaced the DC
          controller PCB, enter the value on the service label.
          Adjustment –50 to 50 (0.1 mm units)
          range (Value at time of factory shipment: Factory-adjusted value)
          (Value after RAM clear: –20)
          PDF Files Created with Universal Send are Slightly Reduced When Printed
          Adobe Acrobat's default print settings will reduce a PDF so that it will completely fit within a printer’s printable area. To prevent this from happening, you must change the 'Page Scaling' option in the print dialog window to 'None'. This will prevent Acrobat from shrinking the images to fit inside of the printer’s printable area.
          • copyhere
            • May 2009
            • 112
            Thanks tekcat I will try the secondary transfer roller because it happens equally if it is print from computer or copy from glass.
            I will let you know if that fixes it.
            • Ron314
              • Apr 2013
              • 97
              Could be the transfer belt drive roller or the belt itself. They tend to get dirty or broken or both.
              314159265
              • copyhere
                • May 2009
                • 112
                Solved. It was the secondary transfer roller. I would have never thought that it would have anything to do with this. Thanks so much teckat. I would have never been able to fix this machine without your help.
                • teckat
                  • 16083
                  Welcome.JPG / everyone here helps ,thanks
