help with canon 1060
  • dld65
    Hi all, wondering if anyone has any ideas for our Canon 1060. It was copying and then ground to a halt. I wasn't here when it happened, but the girls said it made some weird noises and now it just won't start scanning when we hit the copy button. It looks like it tries to start but the scanner bar just won't go.
    Thanks!
  • rapidcopierserviceco
    Rapid Copier Service Co
    • 10
    Sounds like the scanner is jammed... possibly check that it is lubed enough to make the scanner move smoothly.
    We provide other dealers with great service on products they don't normally carry. Don't turn away that service call. We can service just about all make and models from most manufacturers. We have factory trained technicians, parts, maintenance kits etc.
    We will do the service under your company while YOU work on upgrading the customer to the products that YOU carry.
    www.rapidcopier.com
    215-942-9766
    866-891-1620
    Fax 215-942-9768
