cannon IR5075 cannot print from computer
  • bumbleby
    • Sep 2025
    I have a problem with the machine ir5075.
    My machine is already connected to the computer, but can not print the document, please help me.
    thank you ..
    results when doing print
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: cannon IR5075 cannot print from computer
    thank you ..
    [ATTACH=CONFIG]20470[/ATTACH]
    Is your machine a printer? What is the Boot type?
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • DAG COPIERS & COMPUTERS
      • Oct 2010
      • 860
      thank you ..
      The two devices may be physically connected but not Electronically. Assuming it is an 'N' version i.e. 5075N, which Interface have you used for connection? Ethernet cable or USB? Have you installed the print processor (Driver) in the computer? If not install latest driver....can get from 'canonusa'.
      • vamoursly
        • Sep 2011
        • 273
        Bit more info needed here, how is it connected to your computer, as above networked, or USB?
        V
        • bumbleby
          I use a LAN to connect koeksi photocopy machine with a computer.
          the "BOARD" on my copy machine program does not exist,
          • bumbleby
            saat saya masuk menu program *28*, menu yang ada haya menu "COPIER dan FEEDER", menu "BOARD" tidak ada di menu program
            • teckat
              • 16083
              go in service mode and <> Print then>
              Post your USER DATA> P PRINT that shows your settings HERE\/
              • spectraindo
                • May 2008
                • 313
                If "BOARD" does not show means that your ir5075 is not a Printer Model, just Copier.
                Press the Counter Check key and Display Configuration, it will show you what the machine is.
