Ir1022if
  • dinbenci
    • Jul 2025
    Ir1022if
    please send me a new firmware for canon ir1022if media4u@net.hr
    thank you
  • teckat
    • 16083
    Re: Ir1022if
    thank you
    Firmware is a software program or set of instructions programmed on a hardware device. It provides the necessary instructions for how the device communicates with the other computer hardware.
    Firmware can be thought of as "semi-permanent" since it remains the same unless it is updated by a firmware updater.
    You can usually find firmware updates by going to the "Support" or "Downloads" area of a manufacturer's website.
    Keeping your firmware up-to-date is often not necessary, but it is still a good idea. Just make sure that once you start a firmware updater, you let the update finish, because most devices will not function if their firmware is not recognized.
