Hi has anyone had a E004 error on a IRADV4035 i have to look at this mc in the morning.
IRADV4035 with E004
Tags: None
Re: IRADV4035 with E004
E004 (IH Power Supply) and E005 (Web absence) do not need
to be cleared
E004 0000 = Thermistor disconnection detection error
-When disconnection is detected with connector for 30 sec continuously.
1. Check connection of the Connector (J2063/J2510/J214).
2. Replace the Film Unit.
3. Replace the Fixing Main Unit.
4. Replace the DC Controller PCB (UN2).**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
check fuses on Main Driver pcb
to be cleared
4. Replace the DC Controller PCB (UN2).Comment
your first post said E004 & not E400
What was it
E400 is a
problem between the Reader Controller PCB and the Document Feeder.
could be a wire tie issueor a interface cable connection issue between Reader and DADF----
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Have you seen this before.Comment
E400 is a
