System software installation
  • ldfrepairs
    • Oct 2012
    • 147
    Looking for insstructions on how to install system software. Help needed.
    drugstore-onlinecatalog.com
  • teckat
    • 16092
    Re: System software installation
    • Who ? are u/ trained tech or key op
    • What ? model
    • When ? did issue happen
    • Where ? is printer located
    • Why ? do u need firmware
    • How ? did this happen
    • ldfrepairs
      • Oct 2012
      • 147
      I am a trained tech. I have not done an upgrade for many years and have forgotten the ip address config. i am upgrading system software for an ir2200
      • teckat
        • 16092
        -need
        SST
        2200 Firmware loaded in SST
        Put printer in download mode
        give your laptop/PC an IP address of 172.16.1.10 with subnet mask of 255.255.255.0
        If the HDD has been replaced or the HDD needed to be corrected, then first FORMAT using SST
        • ldfrepairs
          • Oct 2012
          • 147
          Thanks very much. By chance do you have the bootrom for the IR2200N
          • teckat
            • 16092
            Service Mode>Copier>Version>Boot-Rom, check to see if "N" is displayed next to the version
            Network Boot ROMs are controlled parts and cannot be ordered
            Network Boot Rom DIMM is not stocked as a service part.
            To upgrade a stand alone machine into a network machine, a Multi PDL Kit must be installed.
            The Network Boot DIMM wil be included in the kit.
            • imageRUNNER 2200 /2800 /3300 Multi-PDL Printer Kit-C1 = 6895-A001-AA.
            A Multi PDL Kit and Network Dimm will come standard in an " i " series imageRunner.
